90GT AGAINST 82 Z28 (300HP)?
I"m fairly new to mustangs.My buddy has a pretty decent Z.He says he runs mid12's.Here is a list of my current mods.Not complete yet.Do yall think I have a chance at a win.Or will I get embarassed?
Please help cause this guy is cocky!
90 GT 5speed
Lunati cam .050 duration,.509,.509,holley heads 202 intake,160 exaust,63cc chambers,75mm throttle body,75mm egr spacer,75mm mass,1.6 roller rockers,190 lph fuel pump,adjustable fuel reg,double roller timing chain,24lb injectors,3:73 gears,cobra tranny,eibach suspension,bump steer kit, k member brace,strut tower brace, sub connectors,cold air induction,17' rizzas,2 chamber flow master,bassani h pipe,diablo custom chip.
Any idea on HP?Can't wait to finish installing everything.
90 GT 5speed
RE: 90GT AGAINST 82 Z28 (300HP)?
need a better cam and bigger MAf. cam should always have more lift and duration on the exsaust to compisate the smaller exsaust valve. and dthe duration is at .50 not acctauly .50 with 509 lift the duration should be around 230-248, for a 5 speed. make the changess and youll be ok.
cam specs are as follows...
Duration@0.050 221 intake 223exhaust valve lift 0.509 intake 0.509
Lobe seperation angle 112 exhaust opens 3.5 btdc 48.5 bbdc
Closes intake 37.5 abdc -5.5 atdc exhaust
sorry for the half a*** imfo. Is this cam decent?
