timing again
Old Jul 20, 2004 | 01:24 AM
luckythirteen13's Avatar
luckythirteen13
Default timing again
i was going to set my timing to 13* but found that when i took my car to my friend at ford, he set the timing to 15*. i have been running on 15* with 87 octane for a couple of months now. there was been no pinging and no predetination noise. for more power, should i go a little more advanced and run on a higher octane. i remember when i first became a member here, some one or a couple of people talked about setting timming to 19*. is that too much? if 15* is ok with 87 octane, how far can i go with 89 octane? with 91 octane? they dont sell higher then 91 octane at most gas stations in california (by most i mean all but 1). there is one gas station not to far from here that sells 110 octane from a standard pump
Old Jul 20, 2004 | 01:03 PM
WNDSOR's Avatar
WNDSOR
Default RE: timing again
personally i wouldnt go higher than like 12 or so on a stock motor, not a whole lot of need to go real high on timing, just doesnt do a whole of for you and when you stay lower, you dont have to worry (detentation, pinging, which octane)...bolt on mods will help a stock motor more than timing, well depends....but anyway 19 is crazy high, running higher timing wears your motor a little fast, you have to think that they set the factory timing for a reason... a little higher is alright for a stocker, but dont need to until you are making some ponies
Old Jul 20, 2004 | 10:49 PM
nhdungeonracer's Avatar
nhdungeonracer
Lucky13, this is where spending time on a dyno will come in handy.
On the dyno, you will know where to set the timing for the best power. Mine made the most power at 15*. We tried higher, but the hp # came down.
Note that I said "MY" motor made it's best power at 15*. That doesn't mean yours will. Every motor is different. Get some dyno time, then you will "know" where to set "your" timing.
Old Jul 20, 2004 | 10:54 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Most ALL 5.0's make the most power at 14 - 15* initial timing, reguardless of mods. No way you can run an actual 14* on 87 octane, its not possible - period. If your not getting detonation with 87 octane then either you can't hear it or your not at 14* (as in your balancer has slipped). Set your engine at TDC (using the #1 piston, not the balancer) and see where the marks line up to be sure.
Old Jul 21, 2004 | 12:44 AM
luckythirteen13
i know what pinging sounds like, i had it bad with my ranger.
my friend at the dealership set it to what it is. i said set it for performace, and thats how it came back
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
