What are your mods and list?
#31
RE: What are your mods and list?
347 stroker fully forged
Balanced rotating assembly
lunati nitrous cam
zex 125 shot
ford racing lifters
1.6 roller rockers
comp cams hardened pushrods
ac delete
trickflow track heat
3/8 intake spacer
bbk tb 70mm
C&L 76mm kit with MAS
reworked e7's have been ported 3 angle valve job milled 40 185 160 valve's
dual valve springs
double roller timing chain
#30 injectors
msd 6al box
msd rpm selector
msd bronze dizzy gear
zex purge kit
zex rapid fire kit
professional products harmonic balancer
arp head bolts and studs
line honed
BBK long tubes Headers
BBK ORHP
BBK Pulleys
BBK 190lph fuel pump
BBK Fuel Pressure regulator
BBK Fuel liquid guage
Ford Racing 9mm wires
super 40 flowmasters
UPR smog pump delete kit
Autometer 5" monster tach
MSD Blaster coil
MSD Cap and Rotor
Pro 5.0 short shifter
BBK Adjustable Clutch Quadrant and firewall adjuster
Centerforce Dual Friction clutch
5.0 shift ****
D&D K-Member new*
D&D Coilovers (150lbs spring rate)new*
D&D tublar a-arms new*
Lakewood traction bars
BBK heavy duty upper control arms
BBK subframe connectors
BBK lowering springs
BBK caster camber plates
solid motor mounts and tranny mount
battery relocated to trunk *new
3.73s
projectors
billet grille
Removed front sway bar
Removed back seat
lunati nitrous cam
zex 125 shot
ford racing lifters
1.6 roller rockers
ac delete
3/8 intake spacer
bbk tb 70mm
dual valve springs
#30 injectors
msd 6al box
msd rpm selector
zex purge kit
zex rapid fire kit
line honed
BBK ORHP
BBK Pulleys
MSD Blaster coil
MSD Cap and Rotor
5.0 shift ****
D&D K-Member new*
3.73s
projectors
billet grille
Removed back seat
#32
ENGINE
holley 650 dp
2"wood spacer
edel performer289 intake manifold
accel ignition
ford racing air cleaner, msd cap and rotor
alternator, water pump, starter, oil pump replaced with oem equipment
afr 165 heads, upgraded springs (people i got these from took a lot longer than they quoted...wouldnt really recommend them as a company)
chromoly pushrods
trickflow 1.6 roller rockers
double roller timing set
ed curtis custom cam http://www.flowtechinduction.com/
dart sportsman 331 roller block http://www.adperformance.com/
scat forged crank, hbeam connecting rods
probe forged dish pistons
alum flywheel
powerbond sfi harmonic ballancer
spec stage 3+ clutch http://www.specclutch.com/
DRIVETRAIN
tremec tko 5 spd tranny
ford racing aluminum driveshaft
3.55 gears, new posi, 98 cobra 8.8 rear axle full rebuild
pro 5.0 shifter
EXHAUST
jet hot coated hooker super comp long tube headers http://www.jet-hot.com/Pages/coatings.html
havent bought the rest of the exhaust yet...will let you know when it gets to that point
SUSPENSION
sn95 shocks and struts
front and rear sway bar
pro 3i lower control arms
CHASSIS
maximum motorsports 4 point roll bar http://www.maximummotorsports.com/
mm full length sub frame connectors
BODY
entire top assembly replaced
WHEELS
konig 17"
5 lug conversion
pbr 13" front and 10" rear brakes
SOUND
rockford fosgate 300w amp with 2 10"s in the trunk
SECURITY
viper 1000 alarm
external fuel pump with toggle swich
---i think thats about everything
holley 650 dp
2"wood spacer
accel ignition
chromoly pushrods
alum flywheel
DRIVETRAIN
pro 5.0 shifter
EXHAUST
SUSPENSION
CHASSIS
BODY
WHEELS
konig 17"
5 lug conversion
SOUND
SECURITY
viper 1000 alarm
#33
Engine
-306 D.S.S. custom built "bullet" short block. (Engine built to support 750HP)
-ARP main bolts and head bolts.
-Competition Cams double roller timing chain.
-Plasma Moly piston rings.
-Probe Custom blower pistons, fly cut for TFS or Stock heads with oversize valves and high lift cam.
-B41 Anderson Ford Motorsport cam (nitrous, blower cam)
-Anderson Ford Motorsport custom valve springs (3 springs per valve)
-DSS main support Girdle, billet aluminum.
-Ford Motorsport Roller Lifters.
-TFS custom length push tubes.
-Crane 1.6 aluminum roller rockers
-TFS aluminum heads, custom port work on Intake and Exhaust ports.
-Edelbrock short runner intake manifold.
-70 mm throttle body and EGR spacer.
-70 MM Vortech/C&L mass air flow meter.
-K&N air filter.
Suspension
-4 CYL lowered springs, front and rear.
-Lakewood 70/30 drag struts
-Lakewood 50/50 drag shocks.
-South Side Machine lower control arms
-4.10 Ford Motorsport rear end gears
-Stock differential
-Steeda off set rack bushings.
-Ford Motorsport aluminum drive shaft.
-87-93 Ford Mustang Convertible motor mounts
-Granatelli sub frame connectors (welded in)
Brakes
-70 mm Ford Lincoln front calipers.
-87-93 front spindles.
-New front rotors.
-Stainless Steel front brake lines.
-Performance friction carbon metallic brake pads.
-Stock rear brakes drums and pads.
Fuel System.
-255 LPH in tank fuel pump.
-Vortech T-Rex in line fuel pump.
-94-95 Mustang fuel rails.
-24 lb Ford Motorsport fuel injectors.
-Mallory adjustable fuel pressure regulator.
Exhaust
-FlowTech long tube headers.
-3/8 stainless header bolts.
-Off road H Pipe.
-Borla XS1 stainless steal mufflers, with 2.5 inch mandrel bent tail pipes
Electronics
-Crane Fireball HI-6 digital ignition (I think has problems)
-Crane Fireball HI-6 matching coil
-91-93 Mass air conversion upgrade.
-ECM is out of a 93 Mustang GT with an Automatic.
-MSD Ignitions Distributor.
-MSD Digital Retard
-MSD RPM Activated Window Switch
Transmission.
-1992 Rebuilt Borg Warner T-5
-Steel input shaft/bearing retainer.
-Billet steel flywheel.
-Ford Motorsport king Cobra clutch
-Lake wood SFI approved bell housing
-Steeda adjustable clutch cable and billet aluminum clutch quadrant.
-Pro 5.0 power tower shifter.
-Customized shorter throw shift handle.
-Flame ball shift ****.
Cooling
-3 core upgraded radiator
-Twin Electric cooling fans.
Gauges
-Autometer pro-Comp liquid filled gauges for Boost, oil pressure, fuel pressure.
-Autometer water temp gauge.
-Autometer Monster tach with shift light.
-Autometer stand alone shift light. (Have 2 shift lights in car)
-Digital Nitrous pressure gauge
Interior
-Mitsubishi GSX seats
-NO BACK SEAT.
-1 speaker
-Kenwood CD player and add on graphic equalizer.
-1 Rockford Fosgate amplifier.
Nitrous
-2 10lb NX bottles
-NX Purge Valve
-NX plate kit (Jets available for up to a 300 shot)
-Custom made fuel and nitrous lines (from solenoids to plate)
-Stainless Steel braided hose
Exterior
-Performance Red paint, with silver metallic flake mixed in.
-Steeda 2.5 inch cowl hood (pinned).
-87-93 GT ground effect package.
-87-93 rear quarter windows.
-3 piece smoked head lights with Blue headlights.
-91-93 Pony rims (5 star pattern) stripped, sand blasted and painted silver metallic.
-Nitto NT 450 225/45/16's up front
-Mickey Thompson ET Street Drag Radials 255/50/16 out back.
-K&N air filter.
Suspension
-Stock differential
Brakes
-New front rotors.
Fuel System.
Exhaust
-Off road H Pipe.
Electronics
-MSD Digital Retard
Transmission.
Cooling
Gauges
Interior
-NO BACK SEAT.
-1 speaker
Nitrous
-2 10lb NX bottles
-NX Purge Valve
Exterior
