Ignition help please!!
Ok get this. I pulled the spout plug off and set the timing to 13* Before TDC. I put the spout back in and started her up and at idle it advanced the timing to 25* Before TDC I revved it up and it dropped it back down to 13* Before TDC. I let throttle off and it jumped back up to 25* Before TDC. Now if I'm not mistaken its suppose to stay at base timing at idle and advance it when u give it throttle. Maybe I am wrong. Oh and I had the timing light going and for some reason it kept cutting out. It would be working fine and then there would be a good 2-4 sec pause before it would flash again. I had been having a problem with my car running very rich. I guess it could all be caused by bad ignition components. Any ideas on what could be wrong? Any help is greatly appreciated. Only mods I have are full exhaust which I doubt would have any effect on ignition.
RE: Ignition help please!!
No the timing will not stay at the base setting w/ the spout reconnected. It is controlled by the ecm at this point. As for the timing light cutting out, are you having a miss fire issue?
Yes its running very rough. When I first got the car it ran fine the first few times I started it. Then it slowly started to run rich. Then it started to be very rich. Now it sounds like its missing and running very rich. I made a vid for another post I had about the rich problem. I will put it up so u can hear the car run.
Mustang missing
Mustang missing
Fairly new Accell TFI Module. Accel coil, plugs,wires and cap/rotor. The Accel stuff was in it when I got it. Didn't look to be in bad shape. The plugs look horrible. So much carbon on them they are solid black.. I am going to get new OE plugs tomorrow.
I just pulled all the plugs. They all look about the same. Very black. You can smell raw fuel on them and its a very strong smell. The plugs were not gapped correctly they were at about .060 instead of .050.
where is the spout ur supposed to pull when doing the timing.. new at this ford stuff.... 87 5.0,i was told to piggy back 2 wires on the tfi module connector... help any body... need more description then by the distributor like my book says..haha
