Maximum compression @ 87 octane
Old Jul 21, 2004 | 03:44 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
Default Maximum compression @ 87 octane
What is the MAXIMUM compression I can have with plain 87 octane gas. Assuming I have all the timing and ignition mods so I don't have to use that expensive 93 sh-t. [&:]
Old Jul 21, 2004 | 04:12 AM
bobby's Avatar
bobby
Default RE: Maximum compression @ 87 octane
why are u worried about higher compression, just wondering[&:]
Old Jul 21, 2004 | 04:54 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
When replacing stock heads with ones that have smaller combustion chambers, the compression goes up. I'm looking at about 9.5-9.7, just wondering if that can be ran with 87 octane.
Old Jul 21, 2004 | 05:07 AM
bobby's Avatar
bobby
ummm.... i dont think so man, u might need to use 89 or 93, sorry i cant be of more help
Old Jul 21, 2004 | 05:47 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
sh-t. Oh well.
Old Jul 21, 2004 | 06:35 AM
92BOOSTED's Avatar
92BOOSTED
Provided you are at 9.5-9.7to1 comp,you can still use 87 if you back your timing down just a little.
If your worried about the price of gas,why are you building this car?Just asking.
Rye
Old Jul 21, 2004 | 07:24 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
I am not paying for it.
Old Jul 21, 2004 | 11:35 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
I'd say anywhere from the stock 10* to 12*, often times older engines (like 5.0's) over time get carbon buildup in the combustion chamber - raising the effective compression ratio requiring higher octane fuel - so you see even with stock timing some people may need 89 octane.
Really the key is to run as much ignition timing as you can with the fuel you use without getting detonation, so you need to experiment for the best setting with your car.
baddog671
Jul 26, 2016 01:20 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
Big Al's 03
Sep 15, 2015 09:05 AM
