Suttering/idle problem
RE: Suttering/idle problem
ok.. I cleaned the IAC with carb cleaner and cutips, but it did NOT solve my problem.
-Before I cleaned the IAC, the car was taking a while to start up.. unless it was already warmed up.
-The check engine light comes on a few minutes after starting it up.
-At around 5krpm the car just sputters and won't go any farther through the rpm range
The mods on the car:
-3.73 gears
-bbk cold air intake
-bbk 70mm throttle body
-full exhaust(not sure if it has cats.. I just bought the car saturday)
-MSD ignition
I am not sure when the plugs were changed
I did run through fuel injector cleaner, but that didnt work.
The car seems to idle fine, but I dont get why it sputters from time to time and wont go past 5krpm....... maybe spark blowout?
I need a datalogger or atleast a way to check the CEL
-3.73 gears
-MSD ignition
Check your email and see if you can get a factory mass air and I have a factory tb if you want to buy it cheap and see if your car runs any better. I have a 65mm tb and my car ran better with it but ran much worse with an aftermarket mass air. Let me know
yup dude had the same problem, Cleaned my IAC, nutting, spent 400 bucks at ford and nuttin, came home cleaned my MAF, worked like a miricle but stilled idled weird, changed my o2's advanced my timing and BOOM car ripps asphault! (timing was at 8* now im at 15!)
Suggestions……
- Resetting the base idle
- Setting the TPS voltage (Setting it between .8vdc - 1.0vdc is OK, no need to follow the .999vdc setting myth)
- Timing calibration
- Finding possible vacuum leaks.
- DIY KOEO/KOER Self-Tests and Cylinder Balance Test
and if the above link to m y 5 o h.com still doesn’t work, use
- How to run a KOEO, KOER Self-Test codes scan and Cylinder Balance Test instead.
Need to access the system for the failure codes, having the CEL on = hard failure in the system.....no calibration procedure will fix it until you id what the system failure is. You can throw parts(=money) at it, but you will be guessing.....use the ECM, it's also a tool....OH!...in your SN95 the diagnostic connector is behind the RH strut tower, not on the driver side as with the fox bodies.
Alright
I pulled the codes with an OBD1
they are:
332= insufficient EGR flow detected
311= thermactor air system/fault during engine run self-test
314=thermactor air system/fualt during engine run self-test/ left side
Also, after seeing people had problems with the EGR capped.. I noticed the header on the left side of the car(viewing from front) has a spot where something connects and is capped... could this be my problem?? I am guessing the owner before me capped the EGR, which is causing this
local shop said $45 to custom weld the EGR back
sound like my problem???
they are:
TAKE OFF YOUR MASS AIR FLOW AND SPRAY SOME CARB CLEANER ON THE SENSOR IN THE MASS AIR NOT TO MUCH . THEN BLOW IT OUT WITH A BLOW GUN NOT TO CLOSE YOU WILL DAMAGE THE SENSOR . THAT SHOULD STOP IT FROM CHOKE . THAT IS WHAT I DID WITH MY STOCK AIR FLOW . I HAD THE SAME PROBLEM .
