DR questions
#22
RE: launch rpm w. DRs?
ORIGINAL: grabbem88
those are the ones with a couple of lines right?.....
#23
ORIGINAL: Quik
no the ET streets are the lines the ET street radials have grooves in them that could make you htink they could displace water
ORIGINAL: grabbem88
haha, aint that the truth...They 'seem' to be able to displace water, but in reality they're more boyant than Pamela Lee's ****.
#24
I got the MT ET Street Radials But my stang isnt a everyday driver I got 325/50r15's at 10 psi I have very good reuslt at the track they hook very well I would definityl buy another set
#25
ok, well ill be running them on stock turbine rims... so thats what... 7x15 i believe...what size tire should i run on that? any one? and yea i was thinking the Mickey thompsons as well. also... so with my stock set up you guys are saying not to launch it? im confused... should i or not?
#26
I would get a 265/60/r15 I thing someone is selliing a used set in parts for sale section already on rims. If your rear and rear suspension is upgrade launch away. if not take it easy the car will tell p when it too much
#27
ok gotcha... stock suspension and drive train... no launching, ok sounds good to me. if i cant launch the car? will DRs really help my 60s at all? how should i drive diff w. these then street tires??<on the track of course.
#28
also, the tire size you said ( 265/60/r15), i couldnt find anything matching that size? most were 255 60 r15... good? or no? i didnt see any mickeythompson, or BFGs w. those specs you listed... just tryin to get the right size the 1st time, thanks man. yall are helpin alot.
#29
here the link to the thread in the forum https://mustangforums.com/m_2048016/tm.htm If have a stick I would launch it a 2500 rpm but that as much as i would go
#30
Launch it., If it breaks, fix it! You want get the results you are after/expecting if you are afraid of it.
Those 235/60/15s would be a good choice. They have a relatively small footprint, but they can still get you going off the line pretty good.
