torque
Old Oct 2, 2006 | 03:07 AM
ckyguy68's Avatar
ckyguy68
Default RE: torque
what tires are you running?
ORIGINAL: smbikes
on my dyno sheet it sys i have 421ft-lbs at 3800 rpm
Old Oct 2, 2006 | 03:14 AM
smbikes's Avatar
smbikes
Default RE: torque
Esenzza 210 type R tires
Old Oct 2, 2006 | 03:21 AM
smbikes's Avatar
smbikes
Default RE: torque
fule psi have somtehing to do with it?
Old Oct 2, 2006 | 03:26 AM
FullAuto's Avatar
FullAuto
Default RE: torque
What gears are you running? Try some 4.10s.
Old Oct 2, 2006 | 03:33 AM
smbikes's Avatar
smbikes
Default RE: torque
i have 3.73s
Old Oct 2, 2006 | 03:44 AM
ckyguy68's Avatar
ckyguy68
Default RE: torque
so you cant spin 210s with 421 ft lbs? there is something SERIOUSLY wrong.
ORIGINAL: smbikes
Old Oct 2, 2006 | 04:10 AM
Ninety5five0's Avatar
Ninety5five0
Default RE: torque
Thats alot of torque to not be spinning.....
Old Oct 2, 2006 | 04:23 AM
tokinGLX's Avatar
tokinGLX
duke of herb
Default RE: torque
that intake manifold is why you have zero low end. its made to flow from 3500-8000 rpm. i would seriously consider a different manifold, either a weiand stealth or an edel air gap
Old Oct 2, 2006 | 09:29 AM
smbikes's Avatar
smbikes
Default RE: torque
so my intake is killing my low end. whats a intake that has a good bottom but is strong through all the rpm range
Old Oct 2, 2006 | 09:36 AM
92GreyGT's Avatar
92GreyGT
Default RE: torque
What torque converter are you running? The torque converter makes all the difference in the world. a friend of mine has a 1985 Mustang with a 12.5:1 347, TFS heads, a 4.56 gear, and an automatic. He can't even do a burn out because the converter is so tight. He runs 7.50s in the eigth at 96 mph. He's ordering a custom converter from ATI now.
