i want my car to spin off the line , my set up is 302 ci bored 40 over converted to carb; 10.5:1 total compression ratio; stock crank fully balanced; scat rods; hyperutectic pistons; comp cams XE274HR cam .555/.565 lift; 1.6 roller rockers by Scorpion; valve train stud girdle; ford racing polished valve covers; victor jr intake with 1" phenolic spacer; holly 650 CFM double pumper; procomp aluminum heads (ported and polished) with 2.055I, 1.60E valves. It also comes with MSD probillit distributor, MSD 8.5 mm wires, MSD blaster 2 coil, MSD digital 6 plus ignition system off the line my car wont spin a but at about 3300 rpm is starts to pull hard but the real hard pulling to the car is at about 80mph , do i need a good tune or is my set up off
