coolant leak and losing oil under boost
Old Oct 2, 2006 | 11:31 PM
1bad87's Avatar
1bad87
Default coolant leak and losing oil under boost
my car seems to leak coolant only after i take the car out and run it kinda hard. i didnt notice it after just letting it run or runing it easy. the car also loses oil somewhere when running hard. i went to the drags with it a couple weeks ago and make 3 passes and was like a 1/2 quart low on oil when i checked the next day.
here is a pic of the coolant that i found.
it is right where the timing case meets the block. anyone have an idea of where it could be leaking or coming from, and why it only does it when run hard under boost? also any idea on where my oil went?
these may be stupid questions but i dont have a clue as to where to start setting things up diff and what to fix
thanks guys!
Old Oct 2, 2006 | 11:33 PM
1bad87's Avatar
1bad87
Default RE: coolant leak and losing oil under boost
forgot to add, we cleaned it off today and then restarted and let run for 5-10 mins and no leak. pressure tested and still no leak. im clueless!
Old Oct 2, 2006 | 11:34 PM
93 LX FiveO's Avatar
93 LX FiveO
cracked timing chain cover?
Old Oct 2, 2006 | 11:37 PM
1bad87's Avatar
1bad87
idk according to my uncle he said that the timing case has nothing to do with any coolant... but i dont know
Old Oct 2, 2006 | 11:39 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Timing cover, t-stat housing. Try this, drain out some cooland so there it about 3 inches below the bottom of the cap and see what happens.
Old Oct 2, 2006 | 11:42 PM
randy78045's Avatar
randy78045
Assuming you dont have water in your oil or oil in your water, it seems to me youre talking about two different issues...
Old Oct 2, 2006 | 11:44 PM
1bad87's Avatar
1bad87
ok thanks, i will try it tomorrow if i get time after work.
Old Oct 2, 2006 | 11:45 PM
1bad87's Avatar
1bad87
yes it is 2 different issues.
ORIGINAL: randy78045
Old Oct 4, 2006 | 12:51 AM
1bad87's Avatar
1bad87
well i lowered the coolant today and drove it around, got on it and put it to 5lbs a couple times and come back and there was just a bit of coolant there. so what does this mean, or prove by lowering the coolant?
Old Oct 4, 2006 | 12:56 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 1bad87
LOL, haven't figured that one out yet!! I haven't had the oil issue, but I have w/ the coolant. That's how I stopped it from happening.
