MAF/MAS
It is not cal'd for an injector size.
The stock Ford MAF/MAS setups were cal'd to the computer.
The computer contained a separate setting for the fuel injector size.
Aftermarket MAF's are cal'd for injectors, so that a custom tune will not be needed for lager injectors or larger MAF.
What computer are you running?
What MAS?
What size injectors?
jason
What MAS?
jason
ORIGINAL: 393tt
I have the 39lb Cobra blue injectors. So I should probably get an aftermarket MAF that is set up for these?
Even if you have 24Lb injectors with the 93 Cobra MAF/MAS, an A9* computer will not run right.
What computer are you using?
jason
Being more specific I have the 03-04 Cobra "Blue Giant" injectors part # 0 280 156 127. I am pretty sure that it is the stock computer. Car is an '89 gt convertable. Motor is a 393 twin turbo. What kind of MAF should I be running for these injectors/computer set up?
[IMG]local://upfiles/50025/7DE1949FA269478D8A563C206AA74EFB.jpg[/IMG]
What kinds of numbers are you putting out, any idea? I'm guessing that 39's might even be a bit small depending. And yeah, +1 on the MAF/TB thing, depending on the power a 75 TB and bigger MAF might benefit you. MAF should always be at least as big as, preferrably bigger than, the TB.
So what should I look for as far as MAF goes? I am not worried about fuel injectors...I plan on running an alcohol/methanol injection kit to pick up where the injectors start to run out. I am new to Ford EFI and any help I get would be great
I wan't the car to run right with the larger injectors...will a certain MAF fix my bucking problem?
