What is needed to run 12's on my 94 gt?
RE: What is needed to run 12's on my 94 gt?
Alright
what times should I run with this mod list:
-3.73 gears
-bbk cold air
-70mm bbk TB
-150 shot of NX
-Gt40 heads
-comp cam
-same suspension(kyb shocks/struts, lower and upper control arms, eibach lowering springs, camber plates)
-nitto DR's on mach1 17" wheels
-MSD ignition
-full MAC exhaust(no cats or EGR)
-and a good tune
-cobra intake mani
-70mm MAF
-3.73 gears
-bbk cold air
-70mm bbk TB
-150 shot of NX
-Gt40 heads
-comp cam
-MSD ignition
-and a good tune
-cobra intake mani
-70mm MAF
.. ummm a lot faster than me... if u cant run a 12 then i might have to quit the moding thinkg b4 i start lol... that 150 shot of nitrous will help a lot... as long as you hook it... otherwise ull just spin and spin
wow.. so you are saying with all of that, including the NX 150shot.. I will only run low 13's???
my vr4 ran a 12.8@109 with gutted cats, a manual boost controller @ 15psi, k&n, blow off valve(not really a mod), short throw, hotwired fuel pump, underdrive pulleys and a 1.7 60'
ORIGINAL: aode06
gt 40's cost $250 used and cams are lik 150.00 new, no that will not do the trick, thse heads will give you 35 hp over stock and the cam another 15. nothing you will feel
So your telling me you wont feel a 50hp kick in the butt? Thats almost a 25% hp increase over stock...
I've read a few of your "informing" posts and have to question your automotive intellegence
gt40's are fine....i know somebody that is tagging low 11's with them on a stock bottem end. get the right cam intake,and gears. suspension is a must,but iv'e some still on factory junk...and a comp cam cost more than a 150 bucks!...(maybe a ford cam 160 bucks)
