bogs
whens the last time it had a tuneup? plugs, wires, rotor cap/button, timing verified, coolant flushed & filled, grounds checked, MAF, IAC, TB cleaned, Air filter changed, fuel filter changed.... etc. Also does the fuel pump prime when the key is in the accesory posisiton (dash lights on & car off)? Does the motor sputter or just loose power all together?
Full tune up like 2 months ago, includin timing, Havent done a coolant flush, grounds checked? maf and iac cleaned, what do u mean prime? and the car sputters, no power loss. also, theres like an explosion sound coming from inside the TB.
Hi, Did you get the popping / backfiring problem fixed? I have the same problem with my 90 GT. Under a heavy load, it will backfire through the MAF. Does happen every time I give it moderate or full throttle. Any info would be appreciated!
Seanam
Oct 4, 2015 10:15 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
