95 GT
95 GT
I have unplugged the coolant temp sesor so that the fan runs constantly to get cooler idleing temps. With this unplugged, will the car run too lean? It seems to run fine so far, am I safe going this route? Thanks for any advice.
RE: 95 GT
+1 PRO5.0SC Closed loop operation is when the comp uses all the sensors to adjust a/f. If all the sensors are not working properally the comp will not let it run correct and could harm your engine...check this site out it has a lot of decent info
http://www.fordfuelinjection.com/
RE: 95 GT
at an idle the engine would get up around 220* before the fan would kick on. Most people I've talked to said that was common on the SN95's. I have a set of AFR heads on it and would like to see cooler temps. No matter what thermostat I use, it still get to that 220 mark befor the fan kicks on.
RE: 95 GT
ORIGINAL: 2broke2gofast
