5.0 carbed
RE: 5.0 carbed
http://www.jason.fletcher.net/
That site has just about every bit of information you could image for a carb swap.
RE: 5.0 carbed
YAY!!!!!!! CARBURETION ROCKS!!!!! COMPUTERS MAKE CARS BREAK DOWN. ECU Says" O now, he hit the gas pedal, what do i do first, Change gear, Add fuel, let more air in, IM SO CONFUSED, Ill just Burn out an 02 sensor, cause i dont knwop if the air comign in, is equal to ther air going oyt, PLEASE HELP, BING *CHECK ENGINE*, no really just sit there, and check it out, real nice, huh, i tell you somthign is wrong, but i never tell ya what HEHEHE MY LITTLE TRICK ) I LOVE CARBS!!!!!!
RE: 5.0 carbed
dam, lol , ive taken out computers, sold them and installed carbed intakes complete with carb on them , and dizzy(and power wire ign on), disconnect fuel pump harness and instal a low line pump, all which can be had for less than $80 used at pick and pull yards.
On fuel lines, I use my flaring tool kit and I new piece of brake line with fittings($4.00advanced auto parts), but you can use 1/4 inrubber line and two clamps ,( preferrably SILICONE, that way it never burst while driving and cause a fire) $3<
as a tech i got to admit, thats the truth. You break down, its your fuel pump ,spark plugs, dizzy carb, alternator, ignition switch or battery. Nothing that cant be figured out in 5 minutes or less.
