Water in headlights???
Before I upgraded my headlights I had an issue with my head light getting water in it. So I drilled little holes in them so the water can come out. My friend is low on funds so he can't upgrade his head light so I'm going to be drilling little holes in his head lights to keep the water out on Friday.
My question is, is there any other way to keep the water out and where does the water go in from?? Thanks!
RE: Water in headlights???
Not sure but I get moisture in my headlights constantly. I tightened them up like 10 time already and nothing is doing the trick. Im sure wherever Im getting moisture is the same place your getting water! Are they cracked at the top at all?
I upgraded already it was the only way that problem went away but before I did I had to drill little holes in the head lights cause that moisture your talking about started to bulid up and had water constantly in the head light so I just drilled little holes on the bottom so the water can come out. My freind has that same problem on his LX. So he asked me what I did to get the water so I told him I drilles it. So I'm going to be doing it on Friday.
I'm just curious to know if there's a better way to cure that problem.
the bulb comes out the back you dont need to ever break that part open.
ORIGINAL: 7upedition
^+1 and silicone sealant on the bulb housing... that way if you need to change the bulb the silicone will break free.
