VERTS NEED ONLY TO REPLY
RE: VERTS NEED ONLY TO REPLY
full length weld in sub-frame connectors help TONS!!!!
www.maximummotorsports.com sells suspension upgrade kits
that can take it as far as your wallet can handle.
"3rd fastest salom time ever recorded by MotorTrend was set by 1990 LX stang w/ $2,000 MM kit "
subframe connectors are a must.... maxiumum motorsports makes them specifically for verts, also you could install strut tower brace, tubular k member, tubular a arms, upper & lower control arms, all poly bushings, shocks,struts, springs, weld in torque boxes. loose some weight, such as take out the spare tire and jack, relocate the battery over the rear pass tire.... check out maximum motorsports summitt,jegs,bilistien, eibach, kyb, etc. for specific prices and apps.
The sn95 came from the factory with a strut brace and subframe connectors, so mine rides pretty good. That's one reason I got the sn95. That and the top seals much better. I would do subframe and strut brace to start off and see where that gets you.
