getting my Vic. Jrs ported
this is my first time to ever have anything ported and was wondering if $600.00 was a decent price for haveing my Victor Jrs ported to flow enough to make upto 650hp NA, wich is 100hp over the stock rateing. Thanks!
RE: getting my Vic. Jrs ported
LOL dude, 650 NA horsepower on 302 cubes - no way could you do that and the car be streetable - thats over 2 hp per cube, that would have to be a race only engine - if it could even be done NA.
But yea, $600 is a good price for portwork - but what are the person's qualifications - I'd want to ensure this person is good at what he does before he starts cuttin on a $1000 dollar set of heads.
What kinda car you putting these on, and whats your setup? Anything more than a polishing job and bowl work is gonna kill velocity.
hey md hes got a stroker think 408...sol cal ,,thats not bad ..its a hi perf shop??we got a place down here that charges $2000.00 for a port job..we talking all out..each flowed the same..dont take to no jacka$$...they flow fairly well out the box ,,i have a set of thoes in my 408 only bowl blended them ...mine flow 281 cfms on intake at .700 lift and 198 cfms on the exhast at .700 lift..that why i got .700 lift..but got 12.5 to1 compression ,,,whats your compression,,,my combos simalier to a book i have everythings the same as mine but its a 418cu in..same compression had over 600 flywheel h/p...
yeah there for my 408. and the shop is a hiperformance place, i dont know all the #s but the owner is Garrantying 100hp over the non ported heads. my compression is Aproxxximately 9.5 to 1 will be adding a 150 shot or 9 psi undisided, looking for a min. RWHP of 700 with the power adder. i have a super victor intake and 850cfm carb, the intake will be port matched. do you guys think 700 rwhp is in my future or do i need something else.
ORIGINAL: 619socalstang
Oh ok, 408 cubes, so thats about 1.5 hp per cube - much more do-able but still tough. Sounds like you've got a setup that could do it. With a 150 shot I think 700 rwhp is possible, really depends on your cam choice. You're gonna have to rev high to get that kinda power though, Im thinkin like 7k ish - that victor of course is made for that type of rev's, just hope your rods are as well.
Man it sounds like its gonna be a nice engine, good luck with it
im not planning on running mine higher than 7200 ..the cams range is 4500/8000rpms..i got 195 psi cranking pressure,,even with big cam 264/273@,050 .701/.688 112 lc. got 6.5 inches of vacuum,,i got to change my power valve to lower # its open at idle to rich..i got to fix that before i run it..im going for h/p ,,anything over 5250 rpms is horse power..my cam make most power for my app.cam motion nos grind ..i love there cams...i dont have enough vac for power brakes now but have res.can iam putting on,,at 140 plus mph you want to stop.....what your cam specs???
