FUEL PUMP WONT COME ON
My fuel pump died while I was checking my timing. Im only getting 6v at the fuel pump with the ignition on. I bought a new fuel pump relay and when I put it in the fuel pump began running even with the key out. I figured the new fuel pump reay was defective so I exchanged it for another. When I put that one in I was back to only 6v at the fuel pump. Whats goin on?
RE: FUEL PUMP WONT COME ON
Battery fully charged, keep in mind that I had 12v to the fuel pump with the first fuel pump relay. The problem though is that the fuel pump would stay on as long as it was plugged in even with the ignition off.
I checked the switch in the steering column and it is good. I put a voltmeter on the wiring harness where it plugs to the fuel pump regulator and read 12v with key on and 0v with key off. I tapped the fuel pump regulator with a screwdriver and the fuel pump came on but stayed on until it the relay got hot and burned up. Normaly when I turn my key to on I can hear the fuel pump for a couple of seconds and then it will stop until I start the car. What tells the fuel pump to shut off when rails reach pressure?
