speed density to MAF conversion problem
we convereted a buddy of mines 88 car to mass air becuase we just built the motor in it. we took out the old speed dens. harness and put the mass air harness in, everythign was plug and play, but we ended up with an unused gray roundish plug right by the computer that wont hook up to anything... the problem is, the fuel pump is not cutting on.... is there somehting we need to do with that one plug, or do we have to jump any wires?? i tried searching but no help... any help is appreciated
Call Dallas mustang 1-800-MUSTANG. Also, the internet should have some diagrams if you yahoo or google it. My Mass air conversion (prior to Carb conversion) required some tech support too. DM might even be able to refer you to some diagrams and will surely know what that plug is for.
why? computer knows the difference...mine is still map...
are you guys 100% the harness is for a 5.0 mustang? are the salt pepper plugs right? trucks are two pins less than the mustang...i was thinking air bag,cause i had one with that and it wouldn't work...
ORIGINAL: 92hatchLX
Make sure that you unhook your MAP sensor!
Mustangs with mass airflow meters dont have a manifold absolute pressure sensors they have a barometric absolute pressure sensors, so if you do the swap from speed density to mass airflow meter then you need to switch the manifold absolute pressure sensor to barometric pressure sensor.
