Autoxray -EZ_READ 2000 code reader any one have one or used one????
Has anyone used or have experience with the
Autoxray ez read 2000 code reader diag tool
I am thinking of getting one to cover both vehicles obd1 1990 stang and obd2 2001 explorer
any advice is appreciated.
RE: Autoxray -EZ_READ 2000 code reader any one have one or used one????
ORIGINAL: 5pnt0gt
i use one at work all the time not a bad machine for personal use but wouldnt recomend it for a shop.
the one I am looking at only comes with a GM Cable
I woild need to go to advance and get the ford obd1 cable and i'm not sure what obd2 cable I would need
I agree it is good for personal use. you should be able to find a kit that comes with the specific cable you want or with all of them. OBDII is just one cable that works for all cars that are OBDII. that one is not manufacturer specific. I have an older version of the autoxray (maybe 5 - 6 years old. never had any problems with it.
ORIGINAL: 7upedition
buy it.... for sure
buy it.... for sure
ORIGINAL: squad272
I Have a Snap On MT2500 Scanner. I purchased it used off ebay. I have $725.00 tied up in it. I can check most domestic vehicles from 83 to 04 and with the rite adapters could do forein. It also has a trouble shooter which helps diagnose and repair codes. If you look around you can get one cheaper with older cartridges. Do a search on ebay for (Snap On scanner) there are always several on there.
