Help with rockers....I'm confused here.
RE: Help with rockers....I'm confused here.
I was gunna describe how to set lash but I'll give u a website instead. http://www.cranecams.com/?show=techarticle&id=2
go down to adjusting for proper preload. good luck
ORIGINAL: Ninety5five0
Whats oh boy ?
I put in the cam, but the guy helpin me told me it was at 0, so i'm guessing thats what it is.
Whats oh boy ?
We tightened the rocker nut as far as it can, it ran out of thread. Ima go back tomorrow and see what i can do, i'll print out that information in that link above and take that too. It was very helpful and thanks for posting it.
But as said above, I3atR!ce has 40's and stock pushrods and all work out for him, and he has 1.7's. Maybe i'm starting in the wrong spot. But there shouldnt be any movement in the rocker should there ? Maybe we're just approaching it all wrong.
I3atR!ce, what cam are you using ?
It all has to do with the cam right ?
I'm still fairly confused on how everything works with the preload and everything, i'm totally new to all of this, but theres only 1 way to learn, and thats to do it myself, which i am. I guess i was just expecting it all to be all fine and dandy with 0 problems, but we all know thats not possible when doing this kindof stuff.
Any more input would be great. Thanks guys
Also the guy helpin me work on it is more of a chevy guy, but knows his sht pretty well. I'm prolly gonna be over there all day to try and figure this out if its raining, if not then he has to work. But hopefully we can get this straitened out. So pushrod length could be a factor here ?
Donno what the crane part # is. The paper says " This kit is designed to allow stud mounted, adjustable rocker arms to be installed on ford 302-351W engines and dodge 318 (5.2L) - 360 (5.9L) magnum engines "
I can find a summit part # if that would help
