head& intake ????
head& intake ????
what is the better trick flow heads &intake? track heat,r series,street efi ,ect just wondering witch one is the better set up for my mods,70mm tb,75mm maf,24lb inj,150 shot of juice.not sure what to go with but i want to order different cam but t/f heads & intake .
RE: head& intake ????
Well, they have different power bands but your cam will be a big determining factor in that also. On allfordmustangs.com there is a head flow chart, you can compare all the TF heads if you want to do a comparison.
yes, the track heat is designed for EGR-less setups and is not emissions legal, the street heat is 50 states legal and rev limits at 5.5krpm vs. the track heat which will climb to 6.5krpm... "R series: Manifolds are designed for non-EGR engines. Most applications will require a calibrated mass air or adjustable fuel injection computer, aftermarket fuel rails, and adjustable fuel pressure regulator to operate properly." go with street heat and twisted wedge heads and a stage one cam...jmo
y not get the trickflow cam?
