BALL JOINT PROBLEM!!!
I have a sn95 gt. The other day my ball joint broke. I had to have the stang towed to my garage. I took the caliper, bracket and rotor off already. I have order some Steeda x2 ball joints that are made for lowered stangs. The bad ball joint is no longer connected to the control arm. Do I have to take the rest out and how do I put the new ones in once I get them tomorrow? My Chilton manual says you have to replace the control arm, but that[>:] book is for the 1989-93 and I know the cars and front brake setup is very different. Any help is greatly appreciated.
RE: BALL JOINT PROBLEM!!!
http://www.steeda.com/products/_enla...balljoints.php
That is a comparision from stock on the right and the x2 and the left. The only difference is the higher spindle. Do they just get pushed in to the control arm?
ORIGINAL: frankbullitt
do ball joints come in pairs? I sure hope so.
Take a look at this control arm kit. It would most likely be cheaper to change the whole lower control arms.
