cam upgrade for my 95 gt PLEASE HELP
RE: cam upgrade for my 95 gt PLEASE HELP
...stock valve springs are only good for a stock cam, or an aftermarket cam with .470" lift max...anything @.510" or over it = exhaust valve spring coil bind...at 0.544 int./0.555 exh. lift, you're going to be crushing those springs..........just a thought.
Either of the following would work:
1. TFS 2500100 Upgrade - http://store.summitracing.com/partde...5&autoview=sku
2. FMS-M-6513-A50 + FMS-M-6514-A40 - http://store.summitracing.com/egnsea...DS=1&N=700+115
I have the E-cam in my 95 and it lobes pretty good.... As far as a push-rod motor the respond very well to cam upgrades.. Just get the h/c/i package from Trick-flow. I would have but the E-cam was already installed when i got it, so I got a Trick Flow Street Heat intake to go with it.
I have a 95 mustang Gt 5 speed myself and was looking at cams for my car, i was going for the same cam your going for but i heard the same thing (SN95's respond poorly to cams) if i were you and still wanted the cam i would put a set of new heads (Trick Flow), upper, lower intake to go along with it and a new throttle body, but who knows i havent put cams in it so idk how it responds for sure
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
