190lph with stock injectors?
So i just replaced the gas tank and before I did it, this would happen sometimes and now I'm thinking I should just get a new fuel pump. When I step on the gas hard sometimes, there is a slight hesitation and then the power comes streaming but it's doing it now more than before after I had to take the old pump out and put the new one in.
Is the 190lph fuel pump fine with stock injectors and lines?
RE: Bad response, bad fuel pump?
ORIGINAL: nomocobra
the stock unit is like 70 or 80 i think
just the 255 you don't want with a stock set up.....a 155 or 190lph are a great up great..you'll see how weak the stock 88lph pump is... we gain 12 hp when I change my pump this was at only 10k miles as the pump is weak pass 3500 rpms as so mine was
it still wouldn't hurt to get an adjustable fuel pressure regulator and gauge so you can see the working fuel pressure and make adjustments to it as needed to get the best performance. also you didn't mention if you changed the fuel filter when you changed the pump. if not, then change it also.
I guess I ASSUMED he changed the sock when he changed the pump. I sure hope he did anyway! LOL
It would be pretty foolish to go to all the trouble to change the pump and not install a new sock on it!
