Replacing heads...how difficult?
RE: Replacing heads...how difficult?
^ Yup, all you gotta do is remove the radiator and air conditioning condensor. Its a little more work, but not too much. If you have the time for it, i'd go for it. I'm sure removing the motor would make the whole process of taking parts off easier in general, but it most definatly can be done without.
ORIGINAL: r.barn
+1 on the cam, you're 95% there to go ahead and do it too.
just make sure you install new lifters too.
ORIGINAL: SSKiller
You might consider cutting the inner fenderwell of your car. Look at the Anderson Powerpipes also. You can get another pound of boost from their set up.
That stuff can alway be removed and reinstalled, cant it ? I"m not too sure how supercharger plumbing is, but i'm guessing it can come right out if it can go right in. A cam would definatly be worth the while, and you'll be so close already, why not ? Ya know ?
What kindof heads are you plannin on doin ? Just out of curiousity.
If all the right tools are handy, and if you have the time to do it all in one sitting, and a good repair manaul to refer to, i'd say about 3-5 to get the heads off, and about 5-7 to get everything back on. Roughly
ORIGINAL: Ninety5five0
I haven't fully decided on heads yet. If I do just the heads and intake, then I may go with some GT-40s or something. But if I get an entire topend kit, then it's most likely going to be trickflow. I just hope the block can take it! With no forged internals and the added stress of a blower (not to mention nitrous) this is going to be puttin some serious HP through her.
