next mod
I have an 86 GT convert. with a Vortech 5 psi SC, 190 lph FP, 73 MM MAf, 70 MM TB and EGR, 30 lb. inj, FMU TF upper/lower intake, BBK headers, custom bent 3"inch x-pipe with Borla mufflers, Kenny Brown subframe connectors, Koni shocks/struts, pulleys, 160 stat, strut tower brace, 355 gears, short throw shifter, AFPR and FP gauge, Flex lite Black Magic Xtreme electric fan, Fluidyne aluminum rad, anti rtoll sway bar, short throw shifter, MSD 6 AL ignition/blaster coil, AEM wide band gauge A/F gauge, boost gauge, mass air conversion, etc. and am trying to figure out my next mod besides cam, heads.
I think someone told me to do lower control arms and if this is the case what brand would you recommend? Either that, or what other mod do you think I should do.
