Porting heads
Old Oct 24, 2006 | 10:03 PM
LX 90's Avatar
LX 90
Default Porting heads
How much can you port stock 1990 mustang heads?? and how big of an intake and exhaust valve can you get to fit???
Old Oct 24, 2006 | 10:36 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: Porting heads
you can remove a good amount...is it worth the effort ? not really unless you in a stock class....for what you'll have in bigger valves and machine work you can find a nice set of iron gt40 or even a set of aluminum heads...
Old Oct 24, 2006 | 10:40 PM
92hatchLX's Avatar
92hatchLX
I'm sure there's a few horsepower to be had if you've torn down the motor and can't afford a nice set of heads. Maybe a little SOTP feeling? I might be doing that along with some other stuff when I tear down my motor this winter.
Old Oct 24, 2006 | 10:44 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
doing a good match port is all I would advise a rookie to do as you can make matters worse
Old Oct 24, 2006 | 10:47 PM
92hatchLX's Avatar
92hatchLX
Yup, that's all that I was going to do. BTW what's the thermactor bump for? Any specific reason? Hurting anything if you shave it down?
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: 2 kwik
I agree. There is velocity to worry about and porting with out a flow bench or some kind of gauge, chances are very good that more harm than good will come of it. Besides, even a set of professionally ported E7's still suck and will not perform as well as a set mildly prepped (not even ported) aftermarkets. Cost wise it makes no sence at all to put any money into the E7 heads.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
