need help with how to fix codes
Ok i just scanned my car and here is what i got.
334-EGR Valve Position sensor-signal voltage higher than expected.(Closed Valve Position.)
172-Heated Exhaust Gas Oxygen sensor voltage signal indicates "lean" Bank 1
176- Same as above but Bank 2
How do i fix these?
Who makes MIL eliminators for 94 gt's? the only ones i can find are for 96+
How do i fix these?
RE: need help with how to fix codes
ORIGINAL: 95 droptop
Where is the DPFE sensor at i cant find it?
Did you check the egr valve for stuck open?
