How to do anti-theft kill switch?
Anyone know how to rig up a simple switch I can hide behind the dash to
kill the ignition system to keep anyone from stealing car?
or a kit?
or maybe a switch that kills power to the fuel pump?
or a kit?
you can find the switched 12v wire for your fuel pump relay,cut the wire in half and add in your switch.for the ignition you can do the same,i think its a yellow wire in your colum cut in half,add in your switch.imo i would do the fp relay
ORIGINAL: 91stang
i was looking to the fuel pump and then when i got under the dash i just saw a bunch of wires and have no idea which one to cut
You can put the switch Dark green/yellow wire or the red wire on the fp relay
ORIGINAL: 1fastzook
Your fuel pump relay should be under your seat or under your hood on the pass side by the intake tube.Just get a dvm or a computer safe test lite and check the wires.
ORIGINAL: 91stang
