Fuel Gauge...
Old 10-26-2006, 07:49 PM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
Default Fuel Gauge...
I have given this no thought, and I'm all out of ideas. My gas gauge is pegged at F. Is this one of those very common super easy fixes?
Sidewayz6.0 is offline
Old 10-26-2006, 10:41 PM
fourfivefour
fourfivefour's Avatar
Default RE: Fuel Gauge...
Need more info on what you are working on.
fourfivefour is offline
Old 10-26-2006, 11:55 PM
Sidewayz6.0
Super Moderator
My bad. It's an 88 GT. I'm sure it's just the sending unit, but I thought I'd start a conversation.
Old 10-27-2006, 12:01 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Have you tried unplugging the sending unit to see if it drops. Also, try banging on the dash to see if that helps. Sometimes they stick. Can only be, the gauge, wiring, or the sending unit.
PRO50SC is offline
Old 10-27-2006, 12:06 AM
Ninety5five0
Ninety5five0's Avatar
I had a sending unit go out on me on my old car, it was a chevy tho. But i eventually broke a rod.....[:-]
Ninety5five0 is offline
Old 10-27-2006, 12:07 AM
Sidewayz6.0
Super Moderator
Again, I've literally done nothing to correct the problem. As far as sticking...It's all the way up. I mean any higher and it would be at 12 o'clock.
I suppose I could check the sending unit. The rest of the gauges work fine...So I doubt it's the wiring.
Old 10-27-2006, 12:09 AM
Sidewayz6.0
Super Moderator
If you want a real brain tickler...Solve this problem. My fuel pump doesn't work unless I jump it with the ECC test connector. I'm just going to run a switch at this point. But what the hell is with that?
Old 10-27-2006, 12:10 AM
Dearborn5.0
Dearborn5.0's Avatar
Is this a new problem?
I had a simmilar problem. Someone swapped out the speedo on my car and bolted the cluster together without
looking at where the needle stops were. The needle got flipped around and was always stuck against the stop
saying full all the time. I cut the stop off. Dont do that, just adjust the needle so it can travel its full length.
That said. Check your electronics first. The sender wire is probably shorted to ground somewhere.
Dearborn5.0 is offline
Old 10-27-2006, 12:20 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Sidewayz6.0
Those oversites are the ones that will come back to bite ya. 1 gauge has nothing to do w/ the other. They all use separate wires!! G/L at being lazy!!
PRO50SC is offline
Old 10-27-2006, 12:24 AM
Sidewayz6.0
Super Moderator
I never said I was lazy. I just haven't gotten to that particular problem. One thing at a time here man.
Quick Reply: Fuel Gauge...
