Fuel Pump
Old Aug 7, 2004 | 06:29 AM
NegadivOne's Avatar
NegadivOne
Default Fuel Pump
okay, i know a good amount about cars except im completely in the dark when it comes to fuel systems. Im thinking about buying a 155lph fuel pump. If I get it, will i need to buy a fuel pressure regulator too?
Old Aug 7, 2004 | 06:39 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
Default RE: Fuel Pump
i dont think you will because stangs have stock regulators that can take care of that. but it is good to have an adjustable one to play with the pressure incase you run boost/higher compression/nitrous.
Old Aug 7, 2004 | 06:59 AM
NegadivOne's Avatar
NegadivOne
where is the stock fuel pressure regulator at? i assume if you get an aftermarket adjustable one, it would go in the same place as the stock one?
Old Aug 7, 2004 | 08:35 PM
vfast's Avatar
vfast
I ♥ Acer
it's on the left fuel rail....I use only kirban....you might have to pull the upper intake to get it in..but you should have it ...please buy a new sock and filter when you go to put it
Old Aug 8, 2004 | 12:24 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
if the fuel pressure regulator is on the left fuel rail, what about the right one? is there a Y connector that connects the single regulator to both banks of injectors?
Old Aug 8, 2004 | 12:57 PM
vfast's Avatar
vfast
I ♥ Acer
the rubber hose in the back of the intake goes to the other side..set your pis @ 35 to start and go from there
Old Aug 8, 2004 | 01:59 PM
roundman's Avatar
roundman
I never knew you could adjust your "pis" LOL
Old Aug 8, 2004 | 02:19 PM
vfast's Avatar
vfast
I ♥ Acer
*L*.....yeah I can as I wanted to be a fireman
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
