thinking about stripping the car anyone interested?
RE: thinking about stripping the car anyone interested?
for everyone else who might be interested:
motor mods:
347 stroker fully forged
Balanced rotating assembly
lunati nitrous cam
ford racing lifters
1.6 roller rockers
comp cams hardened pushrods
ac delete
trickflow track heat
3/8 intake spacer
bbk tb 70mm
C&L 76mm kit with MAS
reworked e7's have been ported 3 angle valve job milled 40 185 160 valve's
dual valve springs
double roller timing chain
#30 injectors
msd 6al box
msd rpm selector
msd bronze dizzy gear
professional products harmonic balancer
arp head bolts and studs
line honed
BBK long tubes Headers
BBK ORHP
BBK Pulleys
BBK 190lph fuel pump
BBK Fuel Pressure regulator
BBK Fuel liquid guage
Ford Racing 9mm wires
super 40 flowmasters
UPR smog pump delete kit
MSD Blaster coil
MSD Cap and Rotor
zex 125 shot
suspension and drivetrain:
Pro 5.0 short shifter
BBK Adjustable Clutch Quadrant and firewall adjuster
Centerforce Dual Friction clutch
5.0 shift ****
D&D K-Member new*
D&D Coilovers (150lbs spring rate)new*
D&D tublar a-arms new*
Lakewood traction bars
BBK heavy duty upper control arms
BBK subframe connectors
Cut stock springs for look
BBK caster camber plates
solid motor mounts and tranny mount
battery relocated to trunk *new
3.73s
Accessories:
projectors
billet grille
monester tach
purge kit
rapid fire kit
nitrous ash tray mount switches
car should be making 300-320 rwhp on motor and stock heads according to total performance
motor mods:
lunati nitrous cam
ford racing lifters
1.6 roller rockers
ac delete
3/8 intake spacer
bbk tb 70mm
dual valve springs
#30 injectors
msd 6al box
msd rpm selector
line honed
BBK ORHP
BBK Pulleys
MSD Blaster coil
MSD Cap and Rotor
zex 125 shot
5.0 shift ****
D&D K-Member new*
3.73s
Accessories:
projectors
billet grille
monester tach
purge kit
rapid fire kit
