Need HELP now!!!!
Old Oct 30, 2006 | 10:57 PM
95 droptop's Avatar
95 droptop
Default RE: Need HELP now!!!!
i have already cleaned both of them, i sprayed them down with carb cleaner. if it help at all my v6 vert was faster. i dont know what the numbers are.
Old Oct 30, 2006 | 10:58 PM
samseed101's Avatar
samseed101
ORIGINAL: P Zero
Most cars if the O2's starts sending a signal that their out of range, the CEL should come on and it would go into whats known as closed loop mode. Closed loop mode is a set of values pre-programmed by the factory, itll send a preset mixture. Should anyway, unless the ECU is bad.
95Droptop, before you go throwin more parts at it DO A COMPRESSION TEST! Thatll let you know what state the motor is in. Is your check engine light on? If so have you scanned it? Thats a good place to start. Another thing, is it blowin smoke out the tailpipes when it runs? Need a little bit mroe info.
-P.
I'm guessing that he did get a CEL, since he mentioned getting "lean" codes. I also found out through personal experience that these things run like crap with bad O2 sensors. I have the same car that he does (sn95 5.0.)
Old Oct 30, 2006 | 11:02 PM
P Zero's Avatar
P Zero
ORIGINAL: samseed101
ORIGINAL: P Zero
-P.
Im just thinkin of typical OBD1/2 cars operation, my probe does that but it still gets up and goes for 207k, I scanned it and the EGR is acting up. That and we've had a run of bad EGR's at my shop thatll cause that same problem. BuT I really think he shoudl start wioth teh comp test though, you never know the previous owner coulda overheated it really bad and now it has super crappy compression.
-P.
Old Oct 30, 2006 | 11:04 PM
95 droptop's Avatar
95 droptop
yes i got a CEL. i might try to get my friend with his 95 gt to come over so i can rob his O2 sensors
Old Oct 30, 2006 | 11:06 PM
95 droptop's Avatar
95 droptop
how much is a compression tester?
Old Oct 30, 2006 | 11:08 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: AdderMk2
clogged cats.... and none of you even saw it comin
Wait a sec... there are people on this forum that don't run o/r midpipes? That's absurd!
pfft.... lol.... 130k on stock cats.... my money says the off road H pipe fixes it for him
Old Oct 30, 2006 | 11:17 PM
Glasersil's Avatar
Glasersil
Yeah it can't hurt to go with a great sounding H Pipe
Old Oct 31, 2006 | 03:42 AM
95 droptop's Avatar
95 droptop
i think i have found the prob. when i thought my MAF was going bad so i swapped it with my v6 and i didnt switch it back cuz the car ran the same. well i found out that the six only has #14 injecters so i need to get the MAF back off my six.
Old Oct 31, 2006 | 04:10 AM
Ninety5five0's Avatar
Ninety5five0
^oh wow^ that might fix it for yea.
Old Oct 31, 2006 | 05:10 AM
Twisted's Avatar
Twisted
ORIGINAL: P Zero
ORIGINAL: P Zero
-P.
-P.
Not to question your knowledge, Pzero, but what the devil does compression have to do with lean running? Seriously.
