Blown Head Gasket
Blown Head Gasket
My motor lost all compression on #2 and #3 cylinders. I took off the head and found that the head gasket had a chunk missing between the two cylinders. It looked like it was burned out. I couldnt see any damage to the valves or pistons so I'm gonna replace the gaskets and bolt the heads back on. I just dont want this to happen again but I dont know what caused it.
RE: Blown Head Gasket
Yeah, its a new motor. Timing and valve adjustment werent right from the time it was put in the car and it still had the custom chip in it from the last motor I had. I just took out the chip and I'll be sure to adjust valves and timing before starting the motor again. I was adjusting the valves when I noticed the blown gasket.
ORIGINAL: jsklx50
ORIGINAL: jsklx50
Yeah it smelled pretty lean. What kind of gaskets do you use with the procharger?
