this worth $800.00
this worth $800.00
you think these heads would work good
HERE WE HAVE THE ULTIMATE SET OF CYLINDER HEADS FOR YOUR 5.0 MUSTANG. IF YOUR LOOKING FOR A SET OF ALUMINUM CYLINDER HEADS FOR YOUR SMALL BLOCK FORD HERE YOU GO LOOK NO FURTHER YOULL FIND NONE NICER. THESE ARE THE NICEST SET OF USED HEADS YOULL FIND. HERE WE HAVE A LIKE NEW PORTED SET OF TRICK FLOW TWISTED WEDGE TRACK HEAT HEADS FOR YOUR 5.0 MUSTANG OR ANY SMALL BLOCK FORD. THESE HAVE LESS THAN 2500 MILES ON THEM AS YOU CAN SEE BY THE PICS THEY ARE LIKE NEW THESE ARE BOLT ON READY. THEY ARE COMPLETELY ASSEMBLED AND ARE A LEGIT 85 HORSE BOLT ON AND HALF OF THE WEIGHT. THESE ARE ARGUABLY THE BEST AFTERMARKET HEADS FOR YOUR 5.0. AS YOU CAN SEE BY THE PICS THESE ARE DEFFINATELY NOT STOCK TRACK HEAT HEASDS. THE INTAKE VOLUME IS 205 CC. I HAD THE EXHAUST PORTS OPENED UP. AND THE INTAKE SIDE IS PORTED TO A FELPRO 1250. THESE HEADS FEATURE HARDENED MILODON STAINLESS STEEL 2.02 INTAKE VALVES AND 1.60 EXHAUST VALVES THESE HEADS ARE 1300 NEW IN STOCK FORM. THESE HEADS ARE SET UP FOR STUD MOUNT ROCKERS. THEY ARE 3/8” STUDS. THEY HAVE EMISSION PROVISIONS WHICH HAVE BEEN PLUGGED OFF WITH STAINLESS STEEL PLUGS WHICH CAN EASILT BEEN REMOVED IF YOU PLAN ON KEEPING IT SMOG PUMP EQUIPTED. THESE HEADS ARE O-RINGED ALSO WHICH IS A MUST FOR HIGH PERFORMANCE APPLICATIONS. I RAN THESE HEADS WITH 1.6 ROCKERS A STAGE 2 TRICK FLOW CAM AND HAD NO CLEARANCE PROBLEMS. . THESE HAVE HIGHER RATE UPGRADED TRICK FLOW DOUBLE VALVE SPRINGS FOR UP TO A .700 LIFT CAM) 10 DEGREE LOCKS, AND MANGANESIUM BRONZE GUIDES, RETAINERS AND GUIDPLATES. THESE GUYS FLOW SOME AIR. I HAD THESE HEADS MILLED .010 SO THE COMBUSTION CHAMBER IS NOW 59CC FOR SOME EXTRA COMPRESSION AND HORSES THEN I HAD THE COMBUSTION CHAMBERS POLISHED. THE DECK ON THESE ARE FLAWLESS AND GASKET SURFACES ARE PERFECT. I ALSO HAD A 3 ANGLE VALVE JOB PERFORMED WONT BE DISSAPOINTED THIS IS A GREAT SET OF HEADS. THEY ARE BOLT ON READY AND NEED NOTHING. THESE ARE SPOTLESS. LIKE I SAID THEY ARE LIKE NEW AND FLAWLESS NO CRACKS CHIPS OR DINGS THEY DO NOT LEAK, HAVE NOT BEEN OVERHEATED AND NO HEAD GASKET PROBLEMS CHECK OUT THE PICS THEY ARE JUST LIKE NEW. SAVE YOUR SELF SOME MONEY AND BUY THESE USED THERE IS NO RESERVE SO BID AWAY. SHIPPING IS A FIXED 50.00 UNLESS GOING INTERNATIONAL THEN BUYER PAYS EXACT AMOUNT CANADA SHIPMENTS ARE USUALLY 20-25 DOLLARS HIGHER. I ACCEPT PAYPAL AND MONEY ORDERS ONLY PLEASE DO NOT BID UNLESS YOU INTEND TO PAY NON PAYING BIDDERS WILL BE REPORTED. PAYMENT IS DUE WITHIN 5 BUSINESS DAYS. NO RETURNS AGAIN THESE HEADS ARE BETTER THAN NEW AND BOLT ON READY
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
