r.barn
Old Oct 31, 2006 | 08:12 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: r.barn
ORIGINAL: randy78045
ORIGINAL: Force4
For all of you that didnt no his motor wasnt running right and the tuning shop couldnt fix it. He has to pull it and send it to a pro build team from what iv heard on the 351 talk.
That suks... [:-]
he probably forgot that the 351w has a different firing order than a 5.0 HO
i hope he didnt install the HO cam in there.... that would be all kinds of bad
Old Oct 31, 2006 | 08:15 PM
r.barn's Avatar
r.barn
Default RE: r.barn
yep, its up at the shop now
they called this morning, said first thing they found was intake valves hitting pistons.
oops, so much for my piston to valve clearance checking skills............
They're fly cutting the pistons and going to double check everything and re-asymble.
Still hoping to have race shop break in and dyno the engine on their engine dyno.
Havent found a carb intake to borrow for it yet though
Dropped off the empty car at the paint shop today to get hood fitted and painted too.
uh, no it doesnt, HO 5.0 has the same firing pattern as 351W, non HO 5.0 does not
Old Oct 31, 2006 | 08:27 PM
nmerrill's Avatar
nmerrill
Default RE: r.barn
beat me to it
Old Oct 31, 2006 | 08:29 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: r.barn
ORIGINAL: r.barn
I stand corrected... ty
There are three kinds of 302s made from 1982-2001.
* 5.0L HO This engine was used in 1983-1995 Mustangs, Mark VII Lincolns, and some T-birds and Cougars. All Explorer 5.0L engines are 5.0L HO engines as well. They use the 351W firing order, 1-3-7-2-6-5-4-8. Except for the 1983-84 Mustangs, all of these engines are roller cam equipped. They use a reverse rotation water pump and front cover. The 1994-5 Mustang and all Explorers use a unique front cover and water pump.
* 5.0L Full Size Car This engine was used in 1982-1990 Crown Victoria and Grand Marquis. They use the 289-302 firing order, 1-5-4-2-6-3-7-8. Most of these cars are not roller cam equipped, however sometime in the early 1990s they started using roller cams but retained the 302 firing order. They use a standard (clockwise) rotation water pump and front cover.
* 5.0L Truck (except Explorer) These engines are similar to the Full Size Car engines, except they use different intake manifolds and camshaft profiles. They also use the 289-302 firing order, 1-5-4-2-6-3-7-8. They also began using roller cams sometime in the early 1990s. They use a reverse rotation water pump and front cover.
FivePointOhh
Oct 25, 2008 11:33 AM
RJW
Mar 23, 2008 05:27 AM
dimebag
Feb 16, 2008 01:29 AM
andywear87
Dec 19, 2007 06:52 PM
Nvarma
Dec 16, 2007 10:07 PM
