5-speed conversion
5-speed conversion
ok i have done just about everything there is to do to these cars except a 5-speed conversion. my aod went out and i am gonna do the convert any tips or things i should look out for would be great.
RE: 5-speed conversion
only site you need to look at....has a printable checklist and everything.
http://www.westcoastfords.com/articl...ap/t5swap.html
I've done them and they are not that bad. Like one guy said the hardest part is the clutch pedal. Just drop the steering column down and move the dash out of the way.....and while you have the dash out you minus well go ahead and replace the heater core. The best thing is the auto wiring harness has the connectors for the clutch pedal, they are just jumped off. Just remove the jumpers and plug them in.
Many say that you don't have to remove the dash, and while it's true you don't, it just makes things go A LOT smoother and less stressfull if you do. Have fun.... it's worth it, just make sure you get a V8 transmission to install back in.
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
jaiidutch
09-14-2015 10:29 AM
YoungStangsMan
09-05-2015 07:01 PM
