AC delete kit
Old Nov 1, 2006 | 10:53 PM
Valentic07's Avatar
Valentic07
Default AC delete kit
i bought the ac delete kit which gets rid of the ac pump and moves the power steering pump to where the ac was. the kit comes with 2 brackets and like 5 bolts and no instructions. anybody know what to do? BTW this is on on fox 5.0
Old Nov 1, 2006 | 11:10 PM
89stanglx's Avatar
89stanglx
Default RE: AC delete kit
I got the same kit about a year ago, just take your time and look at the differences you will figure it out hopefully. It will work 1 way.
Old Nov 2, 2006 | 12:12 AM
Valentic07's Avatar
Valentic07
do you have a pic i could look at?
Old Nov 2, 2006 | 12:40 AM
zemog's Avatar
zemog
thats funny....just got mine in the mail (fed ex) and was gonna ask the same question.
guess i'll just figure it out
david
Old Nov 2, 2006 | 01:21 AM
Valentic07's Avatar
Valentic07
HEY ZEMOG, i figured it out. if you click on his link to cardomain and look at the pic of his engine, it helps ALOT. the bracket that is on the driver side HEAD has to come off, after you take the power steering pump off of it, there is only one bolt that bolts it to the head. then the braket that came with the kit that has the threads in it goes against the HEAD. the side of that braket that is treaded that has one other hole to the left of it points to the upper left hand corner. on the water pump there are two 3 bolts that you took off to get the big braket off. the lower to studs are the ones your going to use for the black braket. the indented part goes on the top bolt because its offset. i have to go get the right size belt now, so if you have any more questions, let me know. but the pics REALLY HELPS
Old Nov 2, 2006 | 03:04 PM
zemog's Avatar
zemog
THANKS for the help ...much appreciated.
z
Old Nov 2, 2006 | 09:01 PM
zemog's Avatar
zemog
all done........thank you
Old Nov 2, 2006 | 09:32 PM
ridebmx4140's Avatar
ridebmx4140
http://static.summitracing.com/globa...-m8511-a50.pdf
Lethaldosage423
Oct 19, 2015 12:12 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
