could i take him??
could i take him??
I have a 1994 mustang gt with a rebuilt motor about 15000miles ago... i have some mods.. here they are
bbk 75mm throttle body
-bbk 75mm mass air
-k&n open element filter
-bbk equal length headers
-3" catted x-pipe
-flowmaster 2chamber mufflers with turn downs
Ford racing t-5 superduty tranny w/ pro 5.0 shifter
-king cobra clutch
-ford racing aluminum driveshaft
-96 saleen rear end with 4.10 gears
-bbk 1.5 inch lowering springs
could i take my friend with a 2000 firebird formula?
-bbk 75mm mass air
-3" catted x-pipe
-king cobra clutch
RE: could i take him??
do you hook or spin ?
w/ tires yes, w/out tires no way , ls1 cars run strong at the top end, capable of 12's all stock , you need to get him hard out of the hole and hope he can't catch you.
I still don't think that a SN-95 5.0 with gears, full exhaust and a few bolt ons could take an LS1 even if he does hook. He might have a better 60' (if the LS1 isn't running slicks also) but the LS1 will run him down.
you've got to downsize your tb, your actually slowing yourself down 75mm = way to big for your mods, 65mm will do for you, if you do a h/c/i swap then 70mm is fine i know people that still run 65mm but 75mm is pointless, and 3" exhaust is also not helping u. go with 2 1/2. 3" is only if your going to FI and you still dont need it then.
ORIGINAL: Ecstasy
also the stock intake on a 94-95 has an internal EGR, and that is your restriction, not your TB. your stock TB is the exact size of your EGR. a bigger TB does absolutely nothing on a stock 94-95 intake.
