wierd problem
RE: wierd problem
Check to make sure your mufflers aren't loose and bouncing off your drive shaft I had the same problem and come to find out the flange bolts came loose and when I made a turn or stopped hard they would hit on the driveshaft. Hope that helps rule out something.
RE: wierd problem
does ur car have a posi rear end? 'cause if it's only happening around corners, it could be that ur posi is engaging and disengaging roughly... check the oil level, but be sure to use limited slip oil in the rear end...
stangin1996gt
09-21-2015 11:01 AM
