what to do with $6000
RE: what to do with $6000
Take some time and figure out what your goal is. Personally, I would look at a 351 w/ some AFR 185's or CNC'd TW's. You can get a shortblock 357 from CHP for under 2500 and then piece the rest of it together yourself. Ebay can be your friend when it comes to used parts like intakes, cams, TB's, etc. No reason to buy new when you can save $$ on parts like that.
okay so heres the list...
DSS 306 longblock with afr 165s
24lb injectors?
edelbrock performer II intake manifold, will these fit the afr heads?
fuel pump (what size?) bbk fuel pressure regulator
oil pump?
oil pan?
70mm throttle body?
65 MAF?
BBK CAI
Timing chain cover
water pump
can i reuse stock pulley/fan pulley?
and i have a AOD will i need anthing to bold up to it?
am i missing anything else? that i should buy brand new and not reuse stock part?
24lb injectors?
oil pump?
oil pan?
70mm throttle body?
65 MAF?
BBK CAI
Timing chain cover
water pump
24lb injectors
190 fuel pump
high volume oil pump
stock oil pan
70mm throttle body
76mm C&L MAF
BBK CAI
Timing chain cover
water pump
electric fan
torque converter
shift kit
K&N panel filter
aluminum radiator
180* stat
24lb injectors
190 fuel pump
stock oil pan
70mm throttle body
76mm C&L MAF
BBK CAI
Timing chain cover
water pump
electric fan
torque converter
shift kit
K&N panel filter
aluminum radiator
180* stat
Coast High Perf.: 306 street fighter GT short block ......... $1,500
Trickflow top end kit ( heads, intake, cam, everything ...... ) .......... $2,300
new flywheel ................... $150
Total ....... $3,950
also ........ a custom cam from Jay Allen will add tons more power too for another $350 or so.
assymbly ............. $2,000 ( by the way thats WAY high )
This would be a much better engine than the GT-40 crate engine.
