Street cam with nice lope...
#24
RE: Street cam with nice lope...
ORIGINAL: Kadence
B cams arnt that great, its a old cam with a realy tight powerband, your best bet is probaly with a TFS 1
A TFS1 has almost the EXACT same specs as an E cam - so I don't see much difference. It may be an older cam but that makes the TFS1 an old cam under a new name.
#27
ford F303 is a great cam, i put one in my 88gt and it just pers, the lope isn't extreme by any means but it has a nice mild idle that sounds absolutley amazing..i also match ported and polished my heads and intake, and 10.5:1 forged pistons and rings for some heavy nitrous. these simple mods alone give the car a deceptively powerful engine while still maintaining good driveability....i believe
f303 has .510 of .512 lift....it really not that much, its just enough to notice a slight difference in idle lope,if you really want a good cam this is the one
#28
I would do the b 303 cam w/ 1.7 rockers or the f303 cam. They will both get through the sniffer here in md. The b 303 will definitly have better low end though and probably be better for stock head intake car. The b303 always makes better power then the e303 even with 1.6 rockers.
#29
ORIGINAL: ZachW04Stang
#30
me and fastman put a B cam in his car, it lopes pretty good. sounds narley, i dont recomend it if you dont havce a 5 speed though cuz sometimes it doesn't like to idle and will just die the EEC4 doesn't like it ;-D but damn driveability its all about lope :-D
