what to look for in a cam?
RE: what to look for in a cam?
ORIGINAL: dimebag
hows this?
the sticky says itll work w. SD.. and it seems to be the biggest lift i can use w. sd, again acording to the sticky... and has the smallest separation i can get w. SD too....
hows this?
Why does SD limit ur cam?
well, sadly... with speed density, im limited... and that seems to be the most i can get. w.out converting to mass air... so says the chart in the stickies...
ORIGINAL: dimebag
right... but that runs me into more $, more time...however you are right tho.. and as for the B cam... its not SD compatable... for now id like to not have to get a chip burned and all...w. that i would have to... did you look at the one i posted... and also... heres the chart in the stickies that im getting some info from...here.
your going to regret it though, your going to go with a cam put it all together and not like it and have to do it all over again so honestly do it all the first time, it slike $350 to get a chip burned, car tuned & dyno'd atleast here it is.
