compression test
Old Nov 10, 2006 | 12:50 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: compression test
ORIGINAL: smbikes
Disable the ignition module or coil.
Insert the compression tester into one cylinder spark plug hole at a time.
Hold the throttle to full open position to ensure the engine gets adequate air intake.
Crank the engine continually for at least five to 10 full revolutions to obtain an accurate reading on the compression tester.
So thats it
Pretty much but I have NEVER held WOT!!
Old Nov 10, 2006 | 12:51 AM
smbikes's Avatar
smbikes
so should i . lol
Old Nov 10, 2006 | 12:52 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Your call.
Old Nov 10, 2006 | 12:56 AM
jays89gt's Avatar
jays89gt
what should comp be ?
Old Nov 10, 2006 | 01:00 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Could be anywhere from 120 - 150 depending on the wear of the engine. Looking mainly for all cylinders to be w/i 10-15% of each other.
Old Nov 10, 2006 | 01:25 AM
smbikes's Avatar
smbikes
do u warm the motor frist??
Old Nov 10, 2006 | 01:27 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
No need to. Just makes it hotter to touch.
Old Nov 10, 2006 | 01:30 AM
smbikes's Avatar
smbikes
ok, so just let it idle for about 2-3 minutes
Old Nov 10, 2006 | 01:35 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: smbikes
Yeah if you want. You're really reading into it a lil much though. Get er done son!!
Old Nov 10, 2006 | 01:42 AM
smbikes's Avatar
smbikes
just how i am , lol, but im on my way now [&:]
