HP gains...
HP gains...
What am i lookin at all said and done with a new (stock) 5.0 with GT40 heads, Cobra manifold, headers back exh with high flows and CAI? Wheel HP i guess. thanks! Any dyno reading would be nice too.
RE: HP gains...
From what ive seen on similiar cars you'll probably be in the 260-270 RWHP range. A Trickflow Stage l or a Comp Cams 281H Camshaft would be a great cam for your application and would put you in the 280-290 RWHP.
RE: HP gains...
ORIGINAL: 2 kwik
damn my internet dyno just went on the blink[:@]
RE: HP gains...
more that 100 and less than 1000... i know its not to the decimal, but thats all i have right now! sorry man, j/k
i'd say high 200's 270-295, depends on the tune, weather @ dyno, supporting mods and condition of the motor.
RE: HP gains...
ORIGINAL: 7upedition
RE: HP gains...
the only thing they did when I got my car tuned is adjust the MAF, timing and fuel pressure.
Old Motor:
Stock 135K bottom End
Stock Heads
B303 cam with 224 duration at 50 and 520 lift with 1.7 roller rockers
Edelbrock Performer Intake
70mm Throttle Body
75mm MAF Sensor
19lb Injectors
It made 253 RWHP/ 311 RWTQ the first pull.
Then it made 272 RWHP and 331 RWTQ after they adjusted the MAF, timing and fuel pressure.
Dyno tuning is crucial if you want the most horsepower you can get. Although I've seen cars that gain 5 horsepower from a tune and then I've seen cars that gain 100+ horsepower from tune.
Old Motor:
Stock Heads
70mm Throttle Body
75mm MAF Sensor
19lb Injectors
RE: HP gains...
ORIGINAL: 88MustangGX
So once i get all of that ish done, get it dyno/tuned? what will they tune? this is where i get lost
