yeah, its the weird motor thing on the side of the throttle body. Make sure you reinstall it in the exact position you took it off (it will go on upside down). You may have a vacuum leak. Popping through the intake is either a valve (not likely) or ignition (possible but it would have to be extremely retarded) timing issue or a lean condition. A vacuum leak will create a lean condition. Make sure you pulled the SPOUT (spark output. This is a grey jumper plug that runs from a wire off the ignition module and is usually a pink wire) when you reset your timing. This disables the computers ability to control spark advance and will keep you at a base timing.
