8.8 compared to 9:1 compression
Old Nov 12, 2006 | 12:36 AM
5speed GT's Avatar
5speed GT
Default RE: 8.8 compared to 9:1 compression
as usual you are a great sorce of information. so there is no real need to pull the heads off to have them cut to 64cc if they are 65ish now.
Old Nov 12, 2006 | 12:37 AM
AdderMk2's Avatar
AdderMk2
Banned
think of it this way. you have a lower than stock compression.... why not boost?
Old Nov 12, 2006 | 01:26 AM
threeg502's Avatar
threeg502
The .2 point of comp is a tiny amount. Have you played around with your ignition timing? Differant
(newer) cylinder heads offer faster burn rates than past designs. You may have to run LESS spark advace to optimize the combo. Given to choice I'd take better airflow over that small amount of comp. My point is I wouldn't take the heads off my car for .2 compression.
Old Nov 12, 2006 | 04:30 AM
88blackgt's Avatar
88blackgt
boost it, 8.8 is almost ideal
Old Nov 12, 2006 | 11:23 AM
2 kwik's Avatar
2 kwik
I ♥ Acer
it's not 30% use the total hp total it will be like 5%
ORIGINAL: 5speed GT
.038 or .039, I dont remember
I guess 15hp is alot when the head and intake swap(w/ 9:1 compression gt40s) would only yeild about 50hp anyway, so thats like a 30% hp loss.
Old Nov 12, 2006 | 12:33 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Did you have the heads rebuilt before you put them on? New valve job etc.? Also remember that judging if there was a performance gain "by the seat of your pants" is not going to tell you anything.
Old Nov 12, 2006 | 12:58 PM
5speed GT's Avatar
5speed GT
yea, I had a full valve job done with new FMS high lift prings
Old Nov 12, 2006 | 02:39 PM
88blackgt's Avatar
88blackgt
if you're going n/a, you're going to want it higher than 9:1. if you're going boosted you're going to want to stay way you are or go sliiiiiiightly lower. either way, i dont really think 9:1 is worth changing things for
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
