Need help finding injector o-rings and valve springs.
RE: Need help finding injector o-rings and valve springs.
ORIGINAL: 92hatchLX
Thanks for the info frdmstng1986GT. I've almost got this all peiced together now. Here's my list in a nutshell:
-Cam (TFS stage 1):
http://store.summitracing.com/partde...0&autoview=sku
-Timing Chain (trick flow):
http://store.summitracing.com/partde...+0&appfilter=1
-Valve springs (trick flows):
I will also be using a Fel-Pro gasket set from work. Now if I could only find those injector o-rings on Summit... Oh well, maybe my work carries them damn o-rings, I'll have to ask because we just opened an account with Fel-Pro.
ORIGINAL: frdmstng1986GT
i think those would work fine. it looks like they are good up to .600" lift too. upgrade your keepers if you can.. stockones will work fine but i have used the titanium ones before and they were so nice.. the heads had about 150 disasemblies and reasemblies and about 300 dyno runs. we used them when i was in school in a t-bucket.. and they were used over and over again.
-Cam (TFS stage 1):
http://store.summitracing.com/egnsea...43&D=%2D160443
ORIGINAL: 92hatchLX
-Cam (TFS stage 1):
-Cam (TFS stage 1):
i would think they would. i mean.. my buddy has the same injectors in his 90 bmw 545i that i have in my 86. same plugs and everything.. same color too. the only difference was they said bosch and not ford. and if you look at the accel injectors they look pretty much exactly like a ford injector. i always thought an injector was an injector. like as long as they were they same rating you could use 8 different injectors if you had to.
You can get a injector rebuild kit from napa.
I don't run that cam, but those springs are good to like .600 lift(can't find the number yet...if you want em)
Those crane springs are reccomended for flat tappet cams, I think I'll just stick with the TF springs. I appreciate you posting those up for me though. I found some o-rings on summit that'll probably fit my injectors. Thanks for the help guys!
NAPA is the anti-christ! lol, We aren't good friends with the local NAPA that's down the street from my work (I work for Parts Plus as a MA/lube and tire boy)
